Crank no start
214,276 MILES • 3.2L • V6 • 4WD • AUTOMATIC
IVANHOE1$
My vehicle cranks but will not start. There is no spark.
Feb 8, 2018 at 8:32 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Check if you have voltage to the coils at the black/orange wires with the key on run, if not check the CB-4 fuse in the dash fuse box.
Also check if you have voltage to the ignition control module black/yellow wire with the key on run and if not check the CB-3 fuse in the dash fuse box.
Feb 11, 2018 at 11:47 PM
