Brake lights, engine, check VSC system all turned on
200,000 MILES • 2.4L • 3 CYL • 4WD • AUTOMATIC
MDENKYI
This morning, i realised my car listed above (Hybrid) has the brake lights, engine, check VSC system all on. I think all the lights apart from batter is on. I just got a new hybrid battery cells so I am confused. Someone say is the battery others say is the gas cap or maybe the air filter. Any help out there?
Apr 24, 2021 at 2:47 PM
Just to confirm the issue. You have the brake light, check engine light and traction control light on?
We need to start with checking for codes. It is most likely not an air filter or gas cap so we need to know what codes are there to be sure.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
https://www.2carpros.com/articles/brake-system-warning-light-on
The common cause for all these lights to be on is a wheel speed sensor so I suspect we are going to find something related to this.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
However, let me know what questions you have or what codes you have and we can go from there. Thanks
Apr 26, 2021 at 1:30 AM
