The ford focus vibrates loudly when starting engine. It also starts at 2000 rpm or more then lowers after a few seconds. After the vehicle reaches normal operating temperature, the vibration is gone and everything is ok. I have had an upper motor mount which went bad replaced. It seems as if this cold weather is causing this vehicle more problems.
Feb 15, 2014 at 4:30 AM
