My 2002 ford focus zx5 vibrates entire vehicle on startup.
168,200 MILES • 2.0L • 4 CYL • FWD • MANUAL
CHRISTOPHER100
  • 13 POSTS
The ford focus vibrates loudly when starting engine. It also starts at 2000 rpm or more then lowers after a few seconds. After the vehicle reaches normal operating temperature, the vibration is gone and everything is ok. I have had an upper motor mount which went bad replaced. It seems as if this cold weather is causing this vehicle more problems.
Feb 15, 2014 at 4:30 AM
HOMER1967
  • 875 POSTS
any check engine light? any codes present? it sounds like you may have a bad idle air control valve.and as far as the vibration,that is very common on these cars and what I have discovered is that it is usually caused by the lower rear transmission mount going bad.but fix the high idle issue first.try disconnecting the battery,first positive then negative for about 15 minutes,then hook it back up, first negative then positive and drive it for a day and see if it improves any.
Feb 15, 2014 at 7:50 AM
CHRISTOPHER100
  • 13 POSTS
there is no check engine light on and I have had an idle air control valve placed on the ford focus zx5.
Feb 15, 2014 at 7:25 PM
AMJADE
I have the se problem!! Does yours jerk into reverse??
Apr 12, 2014 at 9:13 AM
HOMER1967
  • 875 POSTS
you may have a vacuum leak,possibly at the manifold or p.c.v. valve.i would suggest that you take it to a shop to have a smoke test done to check for any vacuum leaks when it is cold.
Apr 12, 2014 at 12:50 PM
AMJADE
Now my car won't go into reverse at all...still a vacuum leak??
Apr 14, 2014 at 7:45 AM
HOMER1967
  • 875 POSTS
no,i think you have bigger issues now.
Apr 15, 2014 at 11:25 AM
