will not run after running hard and backfiring three or four times in a row
100,000 MILES • 5.4L • V8 • TURBO • 2WD • AUTOMATIC
GOOSE888
I was running it hard when all of a sudden it started backfiring, three or four times in a row. After that it would not run right so I put it in the shop and it had three broke plugs and a blown intake manifold gasket so I got them fixed. Now since I have them problems fixed all it wants to do when you get in the throttle hard is fluder early not pulling near like it should, while at the same time you can hear the supercharger winding but not pulling. The truck seems to run fine until you want to get in it hard but seriously I need help please! Thanks
Dec 14, 2016 at 10:52 AM
HMAC300
  • 48,601 POSTS
scan for codes and check for vacuum leaks like a hose off, cracked broken etc.
Dec 14, 2016 at 10:24 PM
GOOSE888
My mechanic scanned for codes and checked the hoses and found nothing. I am going to change the fuel filter and see if that helps.
Dec 14, 2016 at 11:46 PM
HMAC300
  • 48,601 POSTS
before you check fuel filter check fuel pressure as well, see link. if this is a turbo make sure you have vacuum to your turbo valve.
Dec 15, 2016 at 1:41 AM
