The heater is not working?
2,241,547 MILES • 5.7L • V8 • AUTOMATIC
SA0704CR
I was trying to see if my vehicle had a filter but I researched that I didn’t, so I had to put the screws back from the compartment box underneath, but I didn’t remove anything else. I just removed the screws so I put everything back and I plugged in the two cables that I removed from the blower and a couple days later I use the Tahoe and the heater is not working I checked everything if there was any loose wires to be connected and there’s none what can I do?
Dec 29, 2022 at 4:21 AM
  • 110,248 POSTS
If that was all that was done, it could be a couple of simple things. First, make sure the two fuses are good and have power. See the attachments below. Note, when checking the fuses, it is important to also confirm there is power available to them.
Next, make sure the connectors are properly connected and not loose.
Also, at the blower motor connector, there is a black wire. Check to make sure it has continuity to ground. You may have pulled that wire by accident.
If the fan has stopped working at all speeds, then suspect either the ground has failed or both fuses have failed.
Let me know what you find.
See pics below. Note: For some reason, I don't have the fuse layout for the under-hood fuse box. It should be on the inside cover when you remove it. Look for Blower Fuse 3. It will be a 50 amp fuse.
Dec 29, 2022 at 3:18 PM
