starts but will not stay running
1994 CHEVROLET 2500
153,000 MILES • 5.7L • V8 • 2WD
MAX GIBSON
My C2500 starts but will not stay running. I have a video of what it is doing. The ECM was saying the air intake valve sensor was bad. I replaced it, the fuel filter, spark plugs, coil, wires, entire distributor with ignition module cap and rotor. Seems to be getting enough fuel and spark. runs smooth. If I give it gas it chokes out. I checked the TPS and it is working. baffled.
Sep 23, 2017 at 4:52 AM
STEVE W.
  • 15,347 POSTS
This sounds like you have an EGR valve that is not closing all the way here is a video of how to check the valve once you remove it.
https://youtu.be/DqUCbbKdWf4
Cheers
Sep 23, 2017 at 4:56 PM
RON EALY
I have exact same problem.
Does anyone have an answer to this? Please!
May 13, 2018 at 2:00 AM
STEVE W.
  • 15,347 POSTS
Same truck and information? Please use this link to give all the information you can as well as things that have been tried already. That way more people will see the question.
May 13, 2018 at 4:41 AM
  • 55,423 POSTS
Lets run the codes it see what comes up it sounds like the fuel pump is going out. Here are two guides to help us get started:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
and
Cheers, Ken
ANONYMOUS
  • 0 POST
I am a little late to this post, but I had this problem and the dealer replaced the EGR valve cost me $330.00 but at least it is fixed.
May 14, 2018 at 12:27 PM
