Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cobalt
Trouble Codes
P Codes (Powertrain)
P0400 - P0499
P0449
Code PO449
2008 CHEVROLET COBALT
165,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
CPERRY54
MEMBER
I changed the vent solenoid,and erased the code and it reappeared within minutes. what could be the problem? Thanks
Feb 20, 2020 at 7:02 PM
Experienced Mechanic
Good morning,
I would go to the solenoid and test for power with the key on to the pink wire. If it does not have power, it cannot work.
Images (Click to enlarge)
Feb 20, 2020 at 8:31 PM
CPERRY54
MEMBER
There is no power at the pink wire. Where do I go from here? appreciate it.
Feb 22, 2020 at 5:03 AM
Check the fuse I circled in the one diagram I sent you.
If there is power at the fuse, you have a wiring issue from the fuse to the solenoid.
Feb 22, 2020 at 10:27 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Check engine light
Engine won't start
