Will not start, not getting power to fuel pump and no power from starter relay to starter
2005 FORD MUSTANG
197,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
BIGTRUCKGUY75
My car listed above won't crank over and the fuel pump is not turning on at the same time. The ignition switch will make the starter relay click. Jumped the starter and it will crank over. I'm not getting power to fuel pump and no power from starter relay to starter.
What do you think it could be?
Oh yeah, hooked up scanner and there are no major codes so it's not showing any security problems.
Apr 2, 2021 at 2:50 AM
Good afternoon,
I attached a wiring diagram for you to view.
Check the relay for power at pin 85 with the key on. That is power for the control side of the relay. The ECM grounds pin 86 to send power to the starter.
The fact you have no fuel pump leads me to a possible bad ECM.
Apr 2, 2021 at 4:03 AM
BIGTRUCKGUY75
Okay, thank you for your reply. I will look into that when I get the car back in the shop.
Apr 2, 2021 at 5:43 AM
You are welcome.
Always glad to help.
Apr 2, 2021 at 6:09 AM
