Multiple (related?) electrical problems
150,000 MILES • 4.2L • V8 • 2WD • AUTOMATIC
MUSTASH7
92 Grand Marquis LX
Auto on/off lights
Have no tail lights.
No Horn
No cigarette lighter
No trunk lock
All the fuses are good under dash and hood.
Brake & Directionals good.
Bulbs are good.
Could these problems be related?
Thanks a lot for any advice.
Feb 16, 2016 at 10:07 PM
WRENCHTECH
  • 20,758 POSTS
Make sure you have checked any larger fuses and fusible links also.
Other than that, the only way you are going to get to the bottom of it is to troubleshoot one of the issues back to a common source using a wiring diagram.
Feb 16, 2016 at 10:30 PM
MUSTASH7
I understand that there is a fusible link near the solenoid but that all I know. Do you know where I can find a wiring diagram?
Would you happen to know if it could be one of the relays?
Thanks very much for your response!
Feb 16, 2016 at 10:36 PM
WRENCHTECH
  • 20,758 POSTS
The fusible links are at the solenoid. Every system has a different wiring diagram so you are going to have to choose which one to troubleshoot and I will get you a diagram for that circuit but if you are not highly trained in electrical work, you won't be able to figure it out.
Feb 16, 2016 at 10:47 PM
MUSTASH7
I can't say I'm highly trained. More of an advanced DIYer.
I need the tail lights and the lighter to work if that's any help
Thanks for your response!
Feb 16, 2016 at 10:54 PM
WRENCHTECH
  • 20,758 POSTS
http://i1198.photobucket.com/albums/aa448/Wrenchtech/41831010.jpg.gif http://i1198.photobucket.com/albums/aa448/Wrenchtech/41831012.jpg.gif https://www.2carpros.com/images/external/41831013.jpg.gif
Feb 16, 2016 at 11:01 PM
MUSTASH7
Thanks a lot Wrenchtech! I'll give it a go
Feb 16, 2016 at 11:26 PM
  • 55,822 POSTS
Nice reply WRENCHTECH :-)
Feb 23, 2016 at 4:45 AM
