Multiple random misfires and flashing sel
144,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
FIBERGLASSDAN
  • 5 POSTS
Took in mech said bad distributor and crankshaft position sensor. Changed both plus cap,rotor,plugs and wires. Cleared codes. On test drive sel started flashing again. Pulled over check codes and it's back and a knock sensor bank 1 code showed up.
Jun 24, 2014 at 2:15 AM
HMAC300
  • 48,601 POSTS
misfire codes are very hard to diagnose and correct a pro does this best as they deal with it all the time. Just because it says knock sensor may not be the case. Unfortunately you'll have to take it back and let him scan it again maybe something might be an internal problem with whatever sensor it is or something making the knock sensor go off.
Jun 24, 2014 at 2:28 AM
FIBERGLASSDAN
  • 5 POSTS
Why would I go back to someone who wanted $800.00 for a bad repair
Jun 24, 2014 at 3:15 AM
HMAC300
  • 48,601 POSTS
then go to another place because the 800 dollar repair may be an internal engine problem. Like I said misfires are very hard to pinpoint.
Jun 24, 2014 at 5:12 AM
FIBERGLASSDAN
  • 5 POSTS
The 800 was for a distributor and ths sensor.
Jun 24, 2014 at 5:24 AM
FIBERGLASSDAN
  • 5 POSTS
If it's internal than the extend warranty should kick in not this bs
Jun 24, 2014 at 5:26 AM
HMAC300
  • 48,601 POSTS
have an autparts scan it and get back to me they don't charge for it bbut it may be an intermittent due to the flashing light. give me the code it gives.
Jun 24, 2014 at 5:30 AM
FIBERGLASSDAN
  • 5 POSTS
Obdll codes are p0300 and p0328 had it looked at by someone else he said that the intake manifold gasket may be leaking causing my problem. If it is that should be covered under my superior protection plan.
Jun 25, 2014 at 2:52 AM
HMAC300
  • 48,601 POSTS
true if you have a vacuum leak (with a bad manifold gasket) it will cause a misfire normally at lower rpm then smooths out as you go faster.if you spray choke cleaner by the gasket on both sides that would tell you if it's leaking at top. Like I said these are hard to find.
Jun 25, 2014 at 2:56 AM
