Codes P2106, P2173, and P2195, the car starts, revs, then shuts off?
124,000 MILES • 3.3L • AUTOMATIC
BENBOWYER
Hello all, I am a new driver with the vehicle listed above and recently have had some trouble starting the car, because I’m not heaps knowledgeable with the mechanics of cars besides the basics, I thought I’d post in here for answers or at least a lead to what the issue could be. Here are the listed issues:
The car starts, starts revving high, then turns off with a check engine light present (lights and AC stay on).
The diagnosis scanner reads the following error codes: P2106 (PCM forced the car to go into reduced power mode) - P2173 (too much airflow to the engine) - P2195 (Sensor detects a problem with the mixture of fuel and air).
I’ve been told by my stepdad that it’s most likely an issue with the o2 sensor. If anyone can help me out or has any ideas of what it could be that needs fixing or inspected let me know, cheers! Also, happy to give more info in the comments.
Sep 26, 2024 at 9:08 PM
  • 55,746 POSTS
The code P2173 (too much airflow to the engine) is the one we should concentrate on which I would unplug the MAF sensor and start the engine to see if there is any difference. Here is the location of the sensor so you can check it out. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Sep 27, 2024 at 6:02 AM
BENBOWYER
Unplugged the maf and the car started and ran again, going to buy and install a replacement and see how it goes from there, appreciate it!
Sep 27, 2024 at 12:37 PM
  • 55,746 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Sep 28, 2024 at 3:52 AM
