Codes P0339, p0117, P302, and P0303?
145,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
XJSHEN
  • 251 POSTS
After the starter time was longer than usual and hard when I turned on key. I detected car with code reader and found P0339, p0117, P302, P0303 codes appeared. And after changing engine oil, I could not reset oil life. And check oil cap message appeared on the dash. I had worked on the error code one by one and how to replace related parts, but I don’t know the replacement order i.g. Which code should I clear first and so on…… thanks for your comment and helps!
Jun 11, 2024 at 8:27 AM
  • 55,746 POSTS
With these codes the engine may have a larger issue. How does the engine sound when cranking over and when it is running does it sound normal?
P0339: Crankshaft Position Sensor A Circuit Intermittent
P0117: Engine Coolant Temperature (ECT) Sensor Circuit Low Input
P0302: Cylinder 2 Misfire Detected
P0303: Cylinder 3 Misfire Detected
Can you upload a short video of the engine cranking and running? In the meantime, let's do a compression test to make sure the engine is in good shape; this guide can help:
Also, let's swap out the crankshaft sensor and inspect the wiring at the connector. While the spark plugs are out, please check the condition. Check out the images (below). Let us know how it goes.
Jun 12, 2024 at 4:48 AM
XJSHEN
  • 251 POSTS
Dear Ken,
Thanks for your comment. I have replaced the coolant sensor, crankshaft sensor and all spark plugs. Once the engine started and the error codes were all gone. Then, I ran drive cycles, and activated 7 functions accept one function. But car runs roughly compared to before. At first could not erase codes, before replacement parts. How can I do programs relearning without high grade code reader if possible. Thanks for your comment and helps!
Jun 16, 2024 at 2:20 AM
  • 55,746 POSTS
How does the engine run? Have you done a compression test?
Please go over this guide and get back to us.
Jun 16, 2024 at 5:37 AM
XJSHEN
  • 251 POSTS
Engine is running smoothly, no mor rough, acceleration was also recovered. No more code. After replacement of parts, and run twice Drive cycle completely reset to original states. Main issues were resolved now! No more compression test is necessary, there was no any compression related codes found so far.
Jun 16, 2024 at 12:58 PM
XJSHEN
  • 251 POSTS
One problem is that I couldn’t reset the oil life after the new engine oil changed and sometimes a track fuel cap message automatically flashes on the dashboard, and also automatically disappears. What should I do in this situation? Many thanks for your comment and help!
Jun 16, 2024 at 8:44 PM
  • 55,746 POSTS
Glad you could get it fixed, thanks for letting us know. Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Jun 17, 2024 at 4:54 AM
