Multiple codes after engine swap
250,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
BJHASTING
I recently had a new engine put into my Silverado. Right after picking it up I started to get a flashing check engine light at highway speeds around 55 to 60 MPH only. It would stop flashing when I slowed down or stopped. The only code I was getting was P0300 for multiple misfires. Eventually the check engine light came on and stayed on now in addition to the P0300 code I am getting the knock sensor code 4 the bank two knock sensor. I checked the resistance of the knock sensors, and both are within spec. The engine is under warranty, but I've already brought it back to the mechanic once and he said it had nothing to do with the new engine. He changed a bunch of other things, charged me another $2,000.00 and didn't fix the problem. So, I decided to fix it myself.
Jun 23, 2022 at 10:29 AM
  • 55,691 POSTS
What is the brand of rebuilt engine? You will get knock codes if the engine has a lot of internal noise. Also, how does the engine run? Smoothly with plenty of power? I have seen where the fuel pump can get weak causing low fuel pressure which can give the p0300 codes. Also, I would make sure the throttle bore is clean, this guide can help:
Can you please shoot a quick video with your phone so we can hear the engine run? That would be great. You can upload it here with your response.
Jun 24, 2022 at 3:12 AM
