Multiple codes?
32,000 MILES • 6.2L • V8 • 2WD • MANUAL
PJM333
  • 30 POSTS
The car is off the road every year for 5 to 6 months (on trickle charger) and there are always codes when i restart. i disconnect the negative battery cable and all is well. this year that did not happen.
The car drives fine except when i get the “service stabilitrak” light come on, the car goes into limp mode for 10 seconds then drives fine. i have been getting the “service stabilitrak” warning since i bought the car and has been to the dealer multiple times with no answer.
i get the “service stabilitrak” warning light when i drive the car hard, accelerate hard. the spark plugs, coils & fuel injectors have all been changed with no luck.
i did buy a new battery but the codes persist.
1 power steering control module code
u0121 lost communication with anti-lock brake system (abs) control module
1 anti-lock brake system code
u0401 invalid data received from ECM/PCM ‘a'
2 suspension control codes
u0100 lost communication with ECM/PCM 'a'
1 engine control module code
p0300 random/multiple cylinder misfire detected
4 body control module codes
b3205 lf/driver window motor circuit malfunction
b3210 rf/passenger window motor circuit malfunction
b3215 lr window motor circuit malfunction
Jun 2, 2025 at 9:12 PM
  • 55,711 POSTS
The “service stabilitrak” light can come on with no codes due to a bad throttle body or accelerator pedal position sensor. You will get the other codes if the battery is disconnected for a period of time, I would leave it connected but with the tricker charger still on it. Please try replacing the throttle body and accelerator pedal sensor and then clear the codes to see what happens and let me know :)
Ken
Jun 3, 2025 at 4:42 AM
PJM333
  • 30 POSTS
Ken,
Thanks for your reply, I will look into your suggestions and get back to you. Thanks again for your help!
Patrick
Jun 3, 2025 at 5:02 AM
  • 55,711 POSTS
You are welcome, do the replacements and it should fix the problem.
Jun 5, 2025 at 4:44 AM
PJM333
  • 30 POSTS
Had all the plugs changed and the throttle body was cleaned and relearned which fixed p0300 code, but other codes still remain. He said the aps sensor was fine, going back today to discuss other codes. Thanks
Jun 5, 2025 at 10:11 PM
  • 55,711 POSTS
Be sure all fuses are good, you may have a bad PCM. Please start a new thread for the:
Codes. Let me know what is found, I am vary interested.
Jun 6, 2025 at 6:35 AM
PJM333
  • 30 POSTS
Ken,
Thanks again for your help, I will keep you posted, thanks again!
Patrick
Jun 6, 2025 at 6:41 AM
PJM333
  • 30 POSTS
Ken,
All of the window codes have disappeared for some reason, I have driven the car 2 times since I had the plugs replaced and once again I getting the p0300 code again. Like I mentioned before I have been getting this code since day 1 with multiple plug & coil changes. What else can a p0300 code be caused by ? Thanks !
Patrick
Jul 5, 2025 at 10:12 PM
  • 55,711 POSTS
It is good we got the other codes taking care of, lets start a new thread for the P0300 issue and take a clean run at it. please post your new question here, you must be logged in.
Cheers, Ken
Jul 6, 2025 at 3:34 AM
PJM333
  • 30 POSTS
Thanks again for all of your help !
Jul 6, 2025 at 10:07 PM
