Battery light flashing on and off, then stays on
156,500 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
ADRIAN PEREZ
Hello, the battery light just start coming on then off and back on. Then staying on. The battery is less then six months old. I checked the wiring and all seems good. I then noticed a smell coming from the serpentine belt area. Almost electrical in nature. Also there is a high pitch whining sound either in park or when the car is moving. One last thing, the speedometer also started to fluctuate.
Aug 11, 2018 at 10:07 PM
Good morning.
The first thing I would do is have the battery load tested.
Then have the alternator tested to be sure it is working correctly. It may be overworking from a bad battery.
Check the battery cable connections as well.
Aug 11, 2018 at 11:27 PM
