Muffler replacement
223,882 MILES • 2.2L • 4 CYL • 2WD • MANUAL
GABBYGILBO
  • 55 POSTS
In replacing the stock muffler am I able to replace it with a smaller muffler, as in size, shape, length?
Jun 19, 2020 at 10:49 PM
You can replace the muffler with anything that you want. The only challenge that you are going to have is mounting it and running new pipes to it. This is work for a muffler shop as they have all the pipe bending machines and welders to do this correctly.
In theory though all the muffler does is dampen the noise so that the vehicle is not so loud. So you can use any muffler you like, you just have to get it to fit and connect the pipes.
https://youtu.be/7M6uH1hnNgQ
Let us know if you have questions. Thanks
Jun 20, 2020 at 1:17 AM
