Hello and welcome to 2carpros. As SCWICKEDSTANG stated on there earlier post, is there a check engine light on? If you have any faults codes for misfires on one bank only for example P0301, P0303, and P0305 then that would indicate a bad oil control valve or faulty air fuel ratio sensor. I just used those codes for example. You may have a P0302, P0304, and P0306 indicating. Bank2 fault? If you can provide additional information that would helps us try to give you better advise as to where to look for the fault.
Aug 22, 2019 at 3:51 PM
