Speedometer not working
180,240 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
PENGUINLOVE
Needles moves when car is started then goes back to 0 mph, but does not move when driving and the odometer is not recording either. Recently that along with my car stereo stopped working after unplugging the wiring harnesses to hook up a JVC stereo which also did not work. the windshield wiper blades are now not working unless I cut the AC off as well as the power locks. I have no idea why this is happening except for maybe that when I disconnected the battery to make the engine light go off that maybe it caused some sort of short? now the engine light is back on and I am having all of these problems. I am sure my husband and I can fix it we just need more of an idea on what and how to go about it. thanks in advance!
Mar 6, 2018 at 4:24 AM
  • 55,721 POSTS
It does sounds like you have some wiring issues. When you installed the radio did you use a wiring adapter to install it or did you do the wiring yourself?
Cheers, Ken
Mar 7, 2018 at 6:15 AM
PENGUINLOVE
We used a wiring harness and yes did the wiring ourselves.
Mar 7, 2018 at 6:35 AM
  • 55,721 POSTS
Since you have a check engine light on lets see what codes are present you could have shorted out the VSS.
Cheers, Ken
Mar 8, 2018 at 1:47 AM
