Engine will not start Catalytic Converter was stolen?
175,000 MILES
THENEILDEAL215
Catalytic converter was stolen. Replaced with cheap catalytic converter. Could smell it and see fumes but ran for six months. Now the motor won't kick on and will only go in neutral. My guy thinks ECU needs to be reset. Where do I start?
Aug 24, 2022 at 5:18 AM
  • 55,748 POSTS
We need to start by running the codes, here is a guide that will help:
If the catalytic converter has come apart it will clog the exhaust system, this will keep the engine from starting as well. I would lift the car up and use a rubber mallet to rap on the exhaust system to see if you hear anything rattling around inside the muffler and cat.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Aug 25, 2022 at 4:43 AM
THENEILDEAL215
Okay so it's throwing 2 codes. P0037 and P0138. Again, I think the catalytic converter is probably not the best but what do you guys think?
Sep 13, 2022 at 9:12 AM
  • 55,748 POSTS
Heater Control Circuit Low (Bank 1, Sensor 2) and P0138 stands for O2 Sensor Circuit High Voltage (Bank 1, Sensor 2) So for sure the post catalytic converter oxygen sensor is bad. I would replace the sensor first to see what happens. here is the location of the sensor and how to change it out in the images below.
Sep 14, 2022 at 4:42 AM
