How much does this engine weigh?
85,000 MILES • 4 CYL • TURBO • 4WD • MANUAL
DIVIDES
  • 903 POSTS
pulling the motor out, without the transmission, can you find out for me what the weight is for this engine? it will come out with the turbo attached need to find the right hoist for it
Aug 22, 2021 at 12:04 PM
SQM
  • 6,383 POSTS
The complete engine weights approximately 380-390 Lbs. The turbo should add about 25-30 lbs. So somewhere in the 405-425 Lbs. range would be the total weight.
Let me know if yo have any questions.
https://www.2carpros.com/articles/how-a-car-engine-works
Aug 22, 2021 at 1:50 PM
DIVIDES
  • 903 POSTS
great, so one ton hoist is enough, even if I use the 1/2 ton hole on it it should also be enough. thanks
Aug 22, 2021 at 3:28 PM
SQM
  • 6,383 POSTS
Yes, one ton will be more than you will need. I personally find it easier to use the 1/2 ton setup as it gives you more room.
Aug 22, 2021 at 4:22 PM
