Motor turns over but will not crank?
125,000 MILES • 1.5L • 6 CYL
GHOST1RIDER
I reset codes on vehicle would crank and idle but would not accelerate. Reset codes now it just turns over want crank
Sep 29, 2022 at 3:57 AM
  • 110,244 POSTS
What codes were present prior to clearing them?
In most cases, a crank no-start condition is caused either by a fuel-related issue or ignition. Here is what I want you to try. See if it starts for a couple of seconds using starting fluid. If it starts and then stalls, we know there is a fuel-related issue. If there is no change, then check to see if there is spark to the plugs.
Here is a link that explains how to check for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Additionally, here is a link you may find helpful as well:
Let me know what you find.
Sep 29, 2022 at 11:52 AM
