Engine and transmission mount issue
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
2K4MEOW
when I start the car engine moves. when I shift it clunks?
Dec 16, 2021 at 9:44 AM
  • 110,248 POSTS
If the engine is rocking, chances are it is the engine strut mount. If possible, record what it is doing and video the engine so I can see how it's moving.
I attached the directions for the engine mounts and trans mount. Take a look through them and let me know if you have questions. Also, pic 5 begins the engine mount strut I mentioned. Check to see if that is where the play is coming from.
See pics below. Note: The directions are for the 3.5L. You didn't indicate a specific size V6, so I went with the most common one used. If that is incorrect, let me know.
Dec 16, 2021 at 11:18 AM
