Motor swap
2011 DODGE AVENGER
160,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JOSHUA R TABITHA THORNBROUGH
I started having a lot of noise coming from the motor. I decided to change the motor because I found a used one cheaper than fixing it. How long would it take to pull the old motor out?
Nov 12, 2018 at 6:16 AM
Good afternoon.
The labor for replacing the complete engine without transfer of parts is 10.8 hours.
If you do not have a lift for this, I would double the time.
If you have to transfer parts from one engine to the other, it pays 14.9 hours.
Nov 12, 2018 at 6:41 AM
