Motor swap
111,111 MILES
J DANGA LANE
  • 6 POSTS
Can I swap my 2005 Galant 4-cylinder engine with the by in my 2004 Galant ls v6 engine?
Oct 17, 2021 at 6:54 AM
SQM
  • 6,383 POSTS
Those engines are not interchangeable. They use completely different drivetrain setup.
For a swap of this kind, only option is to swap both engine and transmission as well as all the computers out of the donor vehicle.
Even then you will have to modify the motor mounts for everything to fit correctly.
It will be a quite complex job, but possible.
Let me know of any questions.
https://www.2carpros.com/articles/how-a-car-engine-works
Oct 17, 2021 at 8:09 AM
J DANGA LANE
  • 6 POSTS
The mounts look the same. Would i need change the wire harness and all as well?
Oct 26, 2021 at 9:35 PM
SQM
  • 6,383 POSTS
If you can swap all the components than it could be a viable option. I am assuming you got a donor car?
Oct 27, 2021 at 2:14 AM
J DANGA LANE
  • 6 POSTS
I have a 2004 LS v6 i totaled and a 2005 ES 2.4l that's i want to put it in.
Oct 31, 2021 at 6:15 AM
SQM
  • 6,383 POSTS
Got it. That is good that you have a donor you can take out all those components. Let me know if you need any instruction on motor replacement.
Oct 31, 2021 at 11:42 AM
J DANGA LANE
  • 6 POSTS
Sorry for late response but would be much help i still have had no luck.
Dec 15, 2021 at 5:10 PM
SQM
  • 6,383 POSTS
So are you still trying to do the engine swap? Let me know what you are experiencing.
Dec 15, 2021 at 10:07 PM
J DANGA LANE
  • 6 POSTS
Yes, I got another 4 cylinder for it but that motor sold to me was shot and I'm getting my refund. I still have my 04 Gallant ls 3.8l. Can you tell me everything needed to be done to swap them?
Dec 15, 2021 at 11:29 PM
SQM
  • 6,383 POSTS
The best option would be to replace the engine with another 2.4L engine. But is you really want to put the 3.8L v6 in it, then you will have to pretty much take out all the components from the donor car. Including the engine, transmission, all the mounts, all the computers etc. and install all those components to the other car. You will also have to take out the exhaust manifolds and the piping as well.
Keep in mind on swap of this type there are always modifications that needs to be done. Which can require modification to the mounts, the exhaust etc.
I have attached engine replacement procedure for bot 2.4L and 3.8L. Keep in mind those instructions are for replacement of the same size engine.
Dec 16, 2021 at 1:39 AM
J DANGA LANE
  • 6 POSTS
I finally swapped my motor but with another 4 cylinder because no time to play with the by yet but my engine I swapped runs good but now my transmission only goes up to third gear and my neutral light darts flashing and the gear doesn't down shift just stays in third gear. Any ideas?
Jan 2, 2022 at 1:46 PM
SQM
  • 6,383 POSTS
Are you getting any codes? Is the check engine light on?
How is the fluid level and fluid condition?
Did something got disconnected and did not get plugged back in properly?
Unless this issue existed before there should not be a good reason for this issue.
Jan 3, 2022 at 2:20 PM
