Motor Stuttering code sayd cylinder 6 misfire.
114,112 MILES • 4.0L • 6 CYL • RWD • AUTOMATIC
WOLFY1971
I'm receiving a code of P0306 which is according to my investigating is a misfire in cylinder six. I have since put new plugs, wires, and coil pack. still have stuttering issues. I also noticed some liquid discharge from the exhaust. I'm out of ideas and don't have allot of money but love my Sport Trac. Please help...?
Sep 6, 2014 at 10:46 AM
WOODROW89
Check your injectors. Also it's a good thing to check and make sure your fuel filter is not dirty or clogged as well as your air filter.
Sep 6, 2014 at 2:19 PM
HMAC300
  • 48,601 POSTS
misfires are very hard to diagnose, have a local pro try it as any sensor can be bad causing it also check for vacuum lines off or broken as well as grommets on engine valve covers.
Sep 7, 2014 at 1:27 AM
WOLFY1971
Thanks for the input. I really appreciate it.
Sep 7, 2014 at 5:51 AM
WOLFY1971
Thank you very much for your time. Taking it in because I've tried a couple different things again and cannot solve the issue. I appreciate your time.
Sep 7, 2014 at 5:53 AM
