Motor replaced ran once now will not start
94,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
NATHANKNUE
I replaced original motor with a 1993 motor it started four or five times and ran by itself rough. now it won't start. still got fire, still got gas, replace distributor, has new plugs new wires.
Mar 24, 2019 at 10:23 PM
SCGRANTURISMO
  • 4,897 POSTS
Did you do any work to the engine like rebuild it, than install it, or did you get from somewhere and install it?
Thanks,
Alex
2CarPros
Mar 24, 2019 at 11:00 PM
NATHANKNUE
I bought an engine from a guy that pulled out of a running truck. I installed it in mine and it ran for five times like I said rough, but no I never did it did anything to it.
Mar 24, 2019 at 11:17 PM
TANKB
  • 19 POSTS
Turn your key on wait for the security light to go off the try and start it. Still getting a crank no start check your pickup coil make sure sure that your cap/rotor not arcing.
Mar 25, 2019 at 3:07 PM
