Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Corvette
Engine
Symptoms
Not Cranking Over
Engine quit turning over
1971 CHEVROLET CORVETTE
54,000 MILES • V8 • 2WD • MANUAL
JOHNNY MOUNTAIN
MEMBER
The engine was turning over fine. Put some gas in the carburetor and went to try to start it again but the engine wouldn't turn. What should I do?
Apr 4, 2019 at 11:58 PM
Experienced Mechanic
Good afternoon,
If you mean it will not turn, then the motor has hydro locked from fluid in the cylinder.
You need to remove the plugs and then crank it and it will push out all the fuel in the cylinders.
Apr 5, 2019 at 5:12 AM
JOHNNY MOUNTAIN
MEMBER
Not hydro locked. Dropped a valve in #5 cylinder
Apr 5, 2019 at 8:05 AM
Wow. After putting gas in the carburetor.
Guess the heads a rw e coming off. Good time to consider a cam upgrade.
Apr 5, 2019 at 8:27 AM
JOHNNY MOUNTAIN
MEMBER
I'm going to keep it as original as I can. I don't want to mess up a '71 numbers matching big block Vette.
Apr 5, 2019 at 8:35 AM
Got it.
Apr 5, 2019 at 8:45 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
