misfires and struggles when trying to accelerate
2005 CHEVROLET
210,000 MILES • 4.3L • V6 • 2WD • MANUAL
SCOTTY555
The truck it accelerates but only lightly touching the pedal when I try to accelerate faster it misfires and struggles to do so often losing power cutting in and out like it is starving for fuel.
Apr 8, 2017 at 9:22 AM
STEVE W.
  • 15,418 POSTS
Well as a starting point I would have a shop do a scan on it to see if it is setting any codes, then do a fuel pressure test and check for any vacuum leaks as a lean condition could cause both problems. You can usually rent/borrow a pressure test kit from a parts store to run the test.
Apr 9, 2017 at 1:07 AM
