Motor mounts replacement
140,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
ALZACK41
  • 20 POSTS
For Motor mount replacement, my options are:
Front a) Genuine, OEM, w/vacuum fitting or
b) Anchor 9508, NO vacuum fitting
Rear - Anchor 9421
Do I need vacuum fitting for the Front mount?
What do you recommend?
Jan 20, 2017 at 1:07 PM
SATURNTECH9
  • 30,869 POSTS
I replaced one of those recently and I ended up using the OEM one with the vacuum fitting on it. For the rear you can use the aftermarket one.
Jan 20, 2017 at 1:52 PM
