While driving I can feel the engine moving and when shifted into gear it jerks, same when shifting through all gears
2000 HONDA ACCORD
1,400,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JOE85
Hey guys, this is my first time on here. When I put it in gear it jerks same when shifting through all gears. I can feel the motor moving while driving and let off the gas. I have replaced all motor and transmission mounts the rear one twice. It gets a little better after I replace the rear one but only for a day or two. It has the hydraulic rear mount.
Nov 21, 2019 at 12:14 AM
  • 110,244 POSTS
What is the idle speed? When it shifts, is it an abrupt shift? Is there any delay when placing it in gear or shifting? Is the transmission fluid clean and full?
This could be a pressure related issue. At first, I was thinking mounts until you said they have been replaced. Has anyone serviced the transmission recently? If the wrong fluid was installed, it can cause these symptoms. Also, there was a technical service bulletin years back which included a hard shift concern. Based on diagnoses, the transmission or torque
converter was replaced for years or 100,000 miles. However, you indicate there are over a million miles on it, so that isn't even a consideration at this point, even if you wanted to argue it.
Regardless, if you cold, let me know the answers to the questions I asked. It may help me. Also, let me know if the computer was scanned.
Nov 21, 2019 at 9:19 AM
