Motor mounts replacement
238,000 MILES • 4 CYL • 2WD • MANUAL
CHERILL MULLER
I'm trying to replace the driver side motor mount. i got all the bolts removed but the mount wont come up. There are still 2 threaded bolts that are there but one side will come up a little the other side wont move. i'm talking about the bracket on top of the mount.
Sep 14, 2020 at 8:10 AM
  • 110,248 POSTS
I attached a pic below. Let me know if that is the mount you are working with and which bolts are giving you trouble. Also, confirm that all bolts have been removed.
Sep 14, 2020 at 11:02 AM
I attached the info on each mount. Can you let me know which one you are dealing with because they do not label them as driver side. Also, can you get a picture of what your mount currently looks like so that we can try to figure out what the next steps are for you?
Let's start with this and go from there. Thanks
Sep 14, 2020 at 11:05 AM
