Motor mounts
112,444 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JAMIE KELLY
On the car listed above passenger side motor mount there is a cheaper part where I can reuse the bracket on the full assembly. it seems the middle rubber is attached to the bottom of the bracket, if I reuse the bracket it look to be the rubber will not be attached is that okay?
Mar 7, 2020 at 3:20 AM
STEVE W.
  • 15,411 POSTS
The replacement rubber part works well. Easy to install as well. Unless the bracket is damaged you can reuse it without issue. Have used just the insert part on a couple of Ford Focus cars, no problems so far.
Mar 7, 2020 at 4:20 AM
