Motor Mounts 2006 PT Cruiser Turbo
75,000 MILES • 4.3L • 4 CYL • TURBO • FWD
ERNIE'S57
I am able to find on your tube how to replace the upper and lower right side motor mounts, pretty simple, but I cannot find anything on changing to lower (middle? round) motor mount or transmission mount on left side. Could you point me in the right direction or web site where I can find it?
Thanks
Ernie
May 3, 2016 at 7:20 AM
HMAC300
  • 48,601 POSTS
not every car is covered, but the manual says to replace right mount you need to pull the engine out to do it.
May 3, 2016 at 8:21 AM
ERNIE'S57
Thanks much for the information.
May 3, 2016 at 9:28 AM
  • 55,673 POSTS
You might be able to loosen the engine mount and lift it to sneak the mount out to the side.
May 8, 2016 at 3:26 AM
