Engine knock?
186,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
KOLEC94
  • 18 POSTS
I was going 70 on the highway and I heard a know the then the engine died. I saw oil under then car and that is about it. the motor is locked up. any idea what it could be?
Apr 5, 2016 at 4:22 AM
KOLEC94
  • 18 POSTS
few hundred miles since last oil change
but just had brake pads changed
Apr 5, 2016 at 4:24 AM
HMAC300
  • 48,601 POSTS
you kind of answered it your self the motor is locked up. it probably leaked oil out from maybe something hitting pan and draining oil out or it had been going bad like a rod bearing for a long time.
Apr 5, 2016 at 5:13 AM
KOLEC94
  • 18 POSTS
Would that make a sound before it broke?
Apr 5, 2016 at 9:39 AM
HMAC300
  • 48,601 POSTS
yes you said it was knocking prior to lockup. you can try turning it over by hand. it could be the cams have locked and not the bottom end, but just from your description I think its' something else. Of course you can always have it looked at by a local pro
Apr 5, 2016 at 11:59 PM
KOLEC94
  • 18 POSTS
No it knocked once then died
Apr 6, 2016 at 4:18 AM
HMAC300
  • 48,601 POSTS
if the motor doesn't turn over with the starter then it should be tried to move backwards and forwards as it can be anything like a bolt binding the motor from a torque converter to a rod frozen. have a local pro look at this because it needs to be physically looked at to make a better diagnosis
Apr 6, 2016 at 5:01 AM
KOLEC94
  • 18 POSTS
Ok I have another question
Being as my oil light is on would that cause a no start?
Apr 8, 2016 at 5:08 PM
HMAC300
  • 48,601 POSTS
see if your engine will turn over by hand, I think your motor is locked up
Apr 8, 2016 at 11:35 PM
