Engine and transmission interchangeability 1999 vs 1997 4.3 liter
1999 GMC SONOMA
150,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
CORCOVADO
  • 7 POSTS
My 1999 GMC Sonoma, 4.3 vortec V6 Automatic, 2wd stepside pickup is in need of a motor (and possible transmission) as well.
I have the opportunity to get a 1997 GMC Sonoma , 4.3 vortec, 2wd automatic, fleetside pickup.
Would the engine and transmission be a direct swap?
I realize some sensors might have to be swapped out from the 1999. But are there major differences?
I'd like to swap out the motor and transmission in one fell swoop, if possible.
Thank you in advance.
Jun 17, 2020 at 6:48 AM
Good afternoon,
Check the VIN on both trucks. The 8th digit has to be the same on both trucks. It makes a difference with fuel mapping.
If they are the same then you are good to go.
Jun 17, 2020 at 7:14 AM
