Motor
175,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
SHANERUSHING
2000 s10 2.2 flex fuel will crank and run but it rough and a hard knock when its idling
Apr 2, 2016 at 10:06 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with gauge auto parts rent it. check fluids as well
Apr 3, 2016 at 1:59 AM
SHANERUSHING
I have done a vaccuum test on it and changed all the lines that was bad. And i have done had it on computer and it jus pulls up map sensor and i replaced it and stilll no different. I need help idk wat else to do
Apr 3, 2016 at 2:02 AM
SHANERUSHING
Is there anyway i can send u a video of it so u can hear it?
Apr 3, 2016 at 2:03 AM
HMAC300
  • 48,601 POSTS
no videos don't do us much good, if you can disconnect one plug at a time and knock disappears then it will probably be in lower end like rod or piston. you might try a compression test and get back to us but al should be with in 20% of each other clean throttle plate on both sides an d iac hole and check for vacuum leaks plus what I replied earlier is about all you can do.
Apr 3, 2016 at 2:30 AM
