Still seem to be having the same issues, and developed a new one. I have changed the camshaft sensor, crankshaft sensor, coil packs, and ignition control module. I have had all the fuel issues tested and fuel is not the problem. The car has always ran and idled just fine when it would start, but now that I changed the ignition control module, when it idles it just kind of bumps/sputters/misfires and sounds like it is trying to die. Most of the time it will start up just fine, but when it does not start and just cranks I am not getting any spark from any cylinder. The rough idling is a new problem which it has never done before, but the no start is still the main problem. I did find that the PCV valve/hose is electrical taped and I can hear and feel air escaping. It obviously been like that for awhile so I do not know if that is causing the all of a sudden sputtering/missing it seemed to develop over night. I am kind of at a loss now so any ideas would be my joy appreciated.
Dec 5, 2016 at 1:11 PM
