more displacement or more number of cylinders
56,000 MILES • 6.0L • V8 • RWD • MANUAL
MUHAMMED ALI BUTT
Hi sir my name is ali I am mailing you to ask one technical question there are two ways to increae power of engine one is to increase the size cubic capacity cc (cylinder size)of the engine and second is to increase number of cylinders there are 6.0 litre v8 and there is 6.0 litre v12 which got more power and what the main different between v12 and v8 when both engines have same 6.0 litre dispalcement well waiting for your reply thanks indeed
Jul 8, 2016 at 8:57 PM
HMAC300
  • 48,601 POSTS
not much other than more cylinders on the v12 but it may not make as much power as the v8 or vice versa. normally a v12 has more cylinders but smaller and less can be made of a smaller displacement piston than a larger one. but there are a lot of variables that go into this even if both are same size.
Jul 8, 2016 at 11:33 PM
