Moon roof not working properly
160,000 MILES • 0.9L • 6 CYL • 4WD • AUTOMATIC
AINSLY
Moonroof won’t tilt or open. Sunshade works fine.
Jun 2, 2020 at 2:08 PM
Good morning,
I attached a wiring diagram for you of the system. There are 2 fuses for the system. Check these fuses for power on both sides with the key in the on position.
This is a power test, not a visual test. You will need a test light or voltmeter to do this procedure.
Let me know the results.
Jun 2, 2020 at 9:31 PM
