moon roof
100,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
ANN HENDRICKS
i do not have a manual. I need to know what the fuse number is to see if it is blown.
Jun 26, 2017 at 4:32 AM
STEVE W.
  • 15,421 POSTS
Fuse 29 is a 5 amp control power fuse it also powers the ABS module so it is likely fine. Fuse number 2 is a 20A fuse that actually provides the power to the motors for the sunroof and the heated seats if you have them. If it blows those are the three items that stop working.
The question then becomes why did the fuse blow, if it did. It is possible that one of the heated seats has a bad heater or the sunroof motor is failing. If that is the case testing those would be a good thing, you do not want the roof motor to fail halfway open in a rainstorm. The seat heater(s) could just be unplugged if one was bad.
Jun 26, 2017 at 7:16 AM
