Moisture affects starting
200,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
GRUMPYONE
  • 8 POSTS
The car is harder to start and stumbles after a moderate to heavy rainfall or fog. After the engine reaches normal operating temperature, it runs fine.
Mar 12, 2019 at 6:49 AM
Good afternoon,
Moisture is getting on the distributor cap and wires that go to the spark plugs.
Try getting some clear spray paint and spray it on the cap and wires. It will seal the parts from moisture getting into the distributor and it not starting.
Mar 12, 2019 at 8:32 AM
GRUMPYONE
  • 8 POSTS
I suspected as much and would further guess either spraying it with some WD 40 once it is wet and/or replacing the cap and rotor.
Mar 12, 2019 at 12:19 PM
Yes, that would be a better option.
No, to WD. That conducts electricity.
Mar 13, 2019 at 5:28 AM
