Where is the automatic transmission modulator valve located?
163,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
JOE1953
  • 809 POSTS
I have a fluid leak somewhere about the transmission. I have to add fluid. I'm not sure if it is leaking from the modulator valve or does it have one?
Jan 22, 2025 at 5:53 AM
  • 55,711 POSTS
This transmission does not have a modulator valve. You will need to raise the car up and use a flashlight to see where the fluid is coming from.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Jan 23, 2025 at 4:23 AM
