Modified exhaust kit needed
85,000 MILES • V6 • 2WD • AUTOMATIC
ROBHEN5
I’m trying to find an exhaust kit I can modify welding if necessary to swap out with my car listed above exhaust that’s rusted badly.
Nov 1, 2020 at 4:29 AM
Good afternoon,
I found only the catalytic converter pipe for you.
The other pipes look to be unavailable due to the age.
https://www.2carpros.com/articles/how-exhaust-systems-work
My suggestion is a shop that makes exhaust systems. It would be a custom job made to what you would like on the car.
Nov 1, 2020 at 4:50 AM
STEVE W.
  • 15,403 POSTS
I would second what Roy said. Find a shop and have a system made up to fit and if the rest of the car is in good shape I would probably go with a full stainless system. It will cost more than plain steel but you won't be replacing it due to rust in a long time. You might try Ford of Europe, that car was sold there longer than it was in the US, however they did create a US specific exhaust to meet the emissions here. Even then you might be able to use much of it and add in the US spec parts like the converter.
Nov 1, 2020 at 5:58 AM
