Mode door replacement?
1,400,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
DAVID HAYDEN
  • 6 POSTS
Heat and air flow mode actuator.
Oct 24, 2023 at 11:30 AM
  • 110,248 POSTS
The actuators you mentioned are two different ones. The mode door actuator is for airflow direction and the temp (heat) is a blend air door. I suspect you are referring to the mode door (air flow direction), so I attached the directions below.
If, however, you need the blend air door actuator (air temperature actuator), let me know if it is for the left or right side.
Take care and let me know if this helps.
Oct 24, 2023 at 11:58 AM
DAVID HAYDEN
  • 6 POSTS
Thanks, not a job for me.
Oct 25, 2023 at 1:33 AM
  • 110,248 POSTS
Dave, other than it being tight to work on, it really isn't that difficult. However, I understand if you are uncomfortable doing it.
If you change your mind, let me know and I'll help you through it.
Take care of yourself,
Oct 25, 2023 at 11:14 AM
DAVID HAYDEN
  • 6 POSTS
My local mechanic said it is a 7-hour job and wants $800.00 to do it. I was not able to tell by the photo what would be involved. Poor eyesight and at 80 it might be difficult, but it sounds like you have a way to do it without taking the dash apart. If we try I would need much better pictures/diagram than you sent before. Thanks, David
Oct 25, 2023 at 11:52 AM
  • 110,248 POSTS
I would be able to help and could look for better pics. However, I need to confirm if it is a mode door actuator or a blend air door actuator. Is it the airflow direction or temperature that is causing problems? If it is the temperature settings, which side is affected?
Oct 25, 2023 at 12:18 PM
DAVID HAYDEN
  • 6 POSTS
Mainly the temperature, sometimes the clicking happens even when the car is just parked or just opening the door will start it clicking. Thanks
David
Oct 26, 2023 at 1:13 AM
  • 110,248 POSTS
If it is the temperature that is the problem, that is easier than the mode door actuator. Just to give you an idea, take a look through this link:
Let me know which side isn't properly working. See pic below.
See pics below. Note: The right side calls for 1.3 hours of labor and the left side calls for 3.5. See pic 2
Oct 26, 2023 at 12:19 PM
DAVID HAYDEN
  • 6 POSTS
Looks great, I will give it a try. Thanks What do I do to support this program? It is great to actually get a qualified answer to a problem.
Oct 26, 2023 at 1:24 PM
  • 110,248 POSTS
Is the air temperature affected on both sides of the vehicle? It should have a dual climate control design. Also, your support is appreciated simply by your return in the future and telling others. The site owner does have a gofundme page specifically to help others, but that isn't required. Here is the link:
https://www.gofundme.com/f/help-us-help-others-get-back-on-the-road
Please don't feel obligated. Also, let me know which side is affected so that I can get you the specifics for your vehicle. The link I included above is how it is done in general.
Oct 26, 2023 at 1:34 PM
DAVID HAYDEN
  • 6 POSTS
It is the driver's side. Thanks
David
Oct 26, 2023 at 10:27 PM
  • 110,248 POSTS
David, I attached the directions below. The only thing I see you may have an issue with is calibration after it is replaced. It requires a scan tool that can communicate with the module. Take a look at the directions. I attached the recalibration procedures in the last pic. Let me know your thoughts and questions.
joe
Oct 27, 2023 at 1:32 PM
