mode door actuator location and replacement instructions needed
85,000 MILES • 2.5L • 4 CYL
DANIELPINOTTI
The air only comes out the floor heater and defroster vents simultaneously, no matter where I select it to go. Nothing comes out of the mid-level vents. I'm thinking I have a bad mode-door actuator and I'd like to know its location and how to replace it. Thanks
Sep 14, 2021 at 2:01 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. The actuator is mounted to the HVAC box under the right side of dash. Here is a tutorial showing how to replace an electric actuator which is similar to yours:
I've attached picture steps below showing how to replace the mode door actuator on your Sundance. Hope this helps and thanks for using 2CarPros.
Sep 14, 2021 at 3:18 AM
