Mode door actuator?
4WD • AUTOMATIC
THATGUYOVERTHERE
  • 7 POSTS
I've recently picked up a cheap 2011 dodge ram slt V8
I'm have no air flow through the face(?) vents.
blower motor works, blending actuator working. i get air to defrost and feet. hot and cold.
can someone please point me to where the actuators are located? i've looked at other pics and they don't seem to match.
thanks!
Nov 17, 2026 at 2:30 PM
  • 55,783 POSTS
Yep, that will do it, here is the location of the MODE actuator which once replaced should fix the problem,
Nov 18, 2026 at 9:57 AM
THATGUYOVERTHERE
  • 7 POSTS
thanks for the reply! so Indonhave to take the whole
dash apart? ugh. anything else I should do while it's apart? cabin air filter? clean the evaporator?
thanks again!
Nov 18, 2026 at 11:22 AM
THATGUYOVERTHERE
  • 7 POSTS
thanks for the reply! so I do have to take the whole
thanks again!
Nov 18, 2026 at 11:23 AM
  • 55,783 POSTS
You might be able to gain access by removing the glovebox. Yes replace the cabin filter, I would not try to clean the EVAP coil, that is a whole other level. Please upload images of the job so I can guide you if needed.
Nov 18, 2026 at 1:32 PM
THATGUYOVERTHERE
  • 7 POSTS
i did not have to pull the whole dash! pulled the radio apart and took out the cup holder. the torx bit to pull apart the radio bezzle, 7mm socket to take out 4 screws for the cup holder.
very accessible after i did that.
i jiggled the connector and the existing one started working again! i did the actuator reset and all is back to normal.
thanks for your help strailer!
Nov 21, 2026 at 2:11 PM
  • 55,783 POSTS
Great work my friend!! Glad you could get it fixed. Please check us out next time you need help, we are here.
Nov 21, 2026 at 5:44 PM
THATGUYOVERTHERE
  • 7 POSTS
i'm guessing start a new thread for starting issue?
Nov 22, 2026 at 7:46 AM
  • 55,783 POSTS
Yes, please post your new question here, you must be logged in.
Nov 22, 2026 at 8:01 AM
