Mode door actuator, after jumping the battery the A/C will only blow on the floorboard?
133,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
EP03
I drive the car listed above Limited. My battery drained and after I jumped it, my A/C will only blow in the floorboard. How do I recalibrate the mode actuator without a scan tool?
Sep 10, 2023 at 11:23 AM
  • 55,721 POSTS
Sure, here is how to recalibrate the blend door actuator:
Alternate Method (without Scan Tool)
Note: Do not operate any HVAC controls while the HVAC control module is calibrating as this may interrupt the process. If interrupted, improper HVAC performance will result.
Ignition Off - Vehicle Off.
Remove the HVAC control module fuse for a minimum of 20 seconds. Install the HVAC control module fuse. Start the vehicle. Wait 1 minute for the HVAC control module to self - calibrate.
Sep 11, 2023 at 10:46 AM
