Mode control actuator replacement
143,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
ROGER PETERSEN
What position do the 2 actuator arms need to be at when replacing the actuator?
Jun 18, 2020 at 10:40 AM
When you say mode control actuator, I assume you are talking about the HVAC system? If so, you should set mode to defrost and then replace the actuator.
Let me know if this is not what you are referring too and we can figure out what other info you need. Thanks
Jun 18, 2020 at 11:19 AM
ROGER PETERSEN
Yes, I meant HVAC. Going to switch it out. I will let you know how it goes.
Thanks
Jun 19, 2020 at 8:53 AM
Sounds great. Let us know how it turns out. Thanks.
Jun 20, 2020 at 11:39 AM
