Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Climate Control
Blend Door Actuator
Location
Where is the mode blend door actuator located?
2002 CHEVROLET BLAZER
228,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
DRYROT
MEMBER
I have good heat and good A/C. Air is only coming out on the forward-facing vents. Will not change to defrost or to floor.
Oct 8, 2022 at 1:34 PM
SQM
Experienced Mechanic
The mode door actuator is located on the top left side of the HVAC module, behind the dash.
See attached for the replacement procedure.
Let me know if you have any questions.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Images (Click to enlarge)
Oct 8, 2022 at 3:59 PM
DRYROT
MEMBER
Thank you for the quick response! I will be tackling this problem tomorrow now that I have the correct information. Will update soon.
Oct 8, 2022 at 4:03 PM
SQM
You are welcome! Let me know how it goes.
Oct 9, 2022 at 2:34 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
